If you decide to use one of the low cost units, do not allow the unit to overheat and allow the unit to cool between uses. Just using the cheaper unit should be okay to fill up and down 5-10 psi but i myself would not recommend them for repeated prolong use. I see my dad with various cheap units that burn out. The last one was one that was part of a jumper/light/compressor from costco.
Sent from my SM-T310 using Tapatalk
