Old 03-22-2015, 06:36 PM   #1
particlewave
Have you checked the airbag retaining frame and its bushings? I'd bet that it is the problem. Mine did the exact same thing with worn bushings.
The first time it happened, I was at work and it blared for nearly an hour before blowing the fuse. Replacing the fuse caused it to honk and immediately blow. Once the frame was fixed, it worked as it should without blowing the fuse when used. I'm not sure why...
It's very possible that a horn is bad, but the retaining frame is an easy fix and should definitely be checked before buying a horn.
