OK, I have been digging through the manual and found the section about wiring. The Mute wire on the Pioneer harness will not be hooked to anything.
The Blue Wire on Harness B (antenna Control) and the Blue Wire on Harness A (System Remote Turn On) will both be connected to the blue/white wire on the Pioneer harness based on the statement in the manual "Connect to an external power amp's system remote control terminal, the auto-antenna relay control terminal, or the antenna booster control terminal".
Thoughts?
Thanks again. John
