Old 03-21-2015, 09:20 PM   #4
KevinH1990
KevinH1990's Avatar
Check out this thread: http://986forum.com/forums/general-discussions/51283-does-anyone-know-vss-wire-02-bose.html
Scroll down to post 13 and you will see picture of the unit with the wire harness connected.
I used this for a reference on the wiring:
http://www.renntech.org/forums/topic/19616-porsche-boxster-avic-d3-installation-instructions/
You will need to make a donation to Renntech to access this file, but it is worth it.
This may also help.
Pelican Technical Article: Changing Your Boxster Stereo Head Unit / Installing Boxster Ipod Integration - 986 / 987
It has been a while since I did this project, but if I recall correctly, the blue wire with the white stripe on the red connector sends the signal to power on the amplifier and the antenna.
