Old 03-21-2015, 09:19 PM   #3
jpc763
jpc763's Avatar
The blue wire on red plug is the amplifer control signal. It is a 12Vdc signal from HU to amp to turn the amp on slight after the HU powers up.
The Pioneer System mute is the same signal, just silly name.
OK, I read the wrong label. The blue wire on the pioneer harness is labeled "System Remote Control". The Yellow Wire with a thin black or blue stripe is labeled Mute.
So does the Pioneer "Mute" wire hook to the blue wire on the red harness?
Thanks for your response. I searched and there are a lot of threads about replacing the head unit but nothing I could find about the wiring harness connections.
Thanks, John
jpc763 is offline   Reply With Quote
