Old 03-21-2015, 12:22 PM   #14
JFP in PA
Originally Posted by redeye280z View Post
The light started flashing immediately after I started the car. The level of coolant was top up to the max line and the engine was still cold. The sensor was fine when I took it from the old tank. Is there any way to test the sensor to see if it is working properly. Also as a note when I disconnect the harness from the plug it still flashes I was under the impressing that unplugging it would stop the light from blinking. Logically it has to be something with the sensor since I have just finished removing all these parts and putting them back.
Have you tried timing the flash and comparing that to the data above?
