Old 03-21-2015, 10:38 AM   #11
redeye280z
2 fast 4 U
I finally did a few more tests today and found that the bleeder valve was leaking. I took it apart and compared it to the one from my tank that was cracked and was surprised to find that the prints were too thin to make a good seal. I had to run to the local auto parts to find some new o rings. I finally put it all back did the test and it held the vacuum so I refilled the system. Now my temperature light won't stop flashing. The tank is a little over filled right now is it possible that the light would flash if you overfill? What could the cause be the sensor was fine in the old tank.
Drive it the way it's meant to be driven!
2000 Boxster S
redeye280z is offline   Reply With Quote
