Old 03-21-2015, 07:58 AM   #10
JFP in PA
I have my suspicions on mine as well but it's difficult to discern the actual culprit. I'm doing a leak down test tomorrow to see if there's some other problem but I get the feeling there's something not right up top.
The o-rings on the bleeder valve can be changed but that shouldn't be necessary on a new or recent tank. How to test it? No idea.
If you think the tank or bleeder are leaking, use a system pressure tester to pressurize the system and then coat the bleeder area with a soapy water mix; if it is leaking, you will get a ton of bubbles.
