Greetings all~
Dug into the cooling system last week and wanted to share what I've found... So far it's pretty ugly
I did make the decision to go ahead and order the CSF aluminum radiators and am glad I did. As soon as I pulled off the bumper and started to loosen the radiators I knew it was the right move. Radiators were fairly clogged up with road debris in between the radiator and A/C. When I started to take off the hoses they were pretty shot too so they are getting replaced as well.
Since this car's motor failed with oil getting into the cooling system is gucked it up something baaaaad. Already got the car on a lift at the shop so I should be able to pull the rest of the coolant pipes to clean them so I can have it wrapped up this weekend. You can see the poo in the video.
http://youtu.be/q5fBq6p1Mkk
So this week more stuffs continued to trickle in and got my radiator and many hoses, although I think I need more. Amazing how many hoses are on these damn cars!! Also got my air filter so I can finish up the intake as well. Also got the mufflers and my pipe bender so once my next order from Verocious arrives we can start fabricating the rest of the cooling system and make the exhaust!
Thanks for following~
J
