Old 03-20-2015, 01:02 AM   #19
KRAM36
Need For Speed
KRAM36's Avatar
Pelican Technical Article: Replacing the Boxster Brake Booster and ABS Controller - 986 / 987
The Boxster is equipped with power brakes that utilize excess vacuum from the engine in order to assist with the pressure needed to apply the brakes.
Since the venturi tube connections are after the MAF sensor, how does the ECU compensate for the loss of air since the MAF sensor told the ECU how much air was coming into the engine?
2003 Boxster S
