Old 03-19-2015, 10:38 AM   #1
JFP in PA
That is a DIN/ISO double flare (sometimes call a "mushroom" flare), which is reusable:
If the end of the tubing looks like a button and the back side angle of the flare is 90 degrees it is the DIN flare. If you look at the true "bubble" photo above, the back side is rounded. You must use a nut with a "lead" for the DIN flare (nut has unthreaded tip).
M1-3 10 x 1.00MM common European/DIN nut with DIN flare
To make this style flare, you need a very special style of tool.
