Hi There,
Pulled the flywheel, was the correct flywheel.
Found 3 bent teeth (2-3mm) on the side with the gap and 4 bent .5mm on the opposite side.
Made the mistake of not double checking parts. Very sure this happened during shipping.
Only did a quick look when I pulled it out of the box to make sure it looked like the old one - it did and put it in - did not notice the bent teeth.
New flywheel required.
Thanks From
Your Canadian Pal
Glenn
