03-18-2015, 04:07 PM
#5
Originally Posted by mikefocke
Assuming you have no maintenance history and no PPI.
Replace oil, inspect oil filter.
Clean radiators, a/c radiators.
Water pump replace with OEM.
Check brake pad wear.
Change brake fluid.
Measure tread depth. Check tire dates. Check wear for signs of misalignment.
Consider paying a Porsche expert an hour or so to look at the car and give his opinions.
Thank you
Originally Posted by cardiffgiant
If you think about doing a coolant flush, also consider changing your termostat, as well as your coolant resevoir.
Thank you
Originally Posted by Giller
Did you do a PPI on it before taking possession? If not, go get one now. That will tell you a lot about what you need to do. That's a lot of miles and a 12 year old car, so I'm sure there are lots of things that could be done. Motor mount, CVs, transmission flush, coolant flush/fix, AOS,....the list is huge of things you could do.
Obviously then the IMS is a big question mark. If it hasn't been done, that is certainly something to consider.
I would highly recommend getting your name on the list for a skybreaker, as it's just wicked cool and all Box's should have one.
Ims done, no ppi, what is skybreaker?
