Old 03-18-2015, 08:55 AM   #19
Smallblock454
Couldn't find out if the LUK number is stamped on the LUK DMF.
These are the infos i got:
LUK 415 0072 10 (G86.00 5 speed transmission - Boxster 2.5)
Porsche OEM 986 114 012 01, 986 114 012 02, 986 114 012 05
EAN: 4005108012746
Max. clearance angle (Freiwinkel): 15 degrees
Amount of teeth max. clearance angle (Freiwinkel): 6 teeth
max. tilting free play (Kippspiel): 1.6 mm
LUK 415 0120 10 (Boxster 3.2)
Porsche OEM 986 114 012 04, 986 114 012 06
EAN: 4005108178145
Max. clearance angle (Freiwinkel): 14 degrees
Amount of teeth max. clearance angle (Freiwinkel): 5 teeth
So if you don't find a number on the DMF, you can still check if it is right by checking the max. clearance angle.
Regards from germany
Markus
