Old 03-17-2015, 11:38 PM   #10
calimanusa
I also bought the 2L deep sump through the Planet-9 group buy. Be sure you have the correct size screws. Mantis initially sent out 40mm screws which turn out to be too long.
From my understanding, there may have been a change in design or the depth of the counter-sinks were bored too deeply, but either way the 40mm screws will bottom out. The correct size is 35mm. Unfortunately, I learned this the hard way as I was one of the first to install the 2L sump from the group buy. The long screws bottoming out caused my engine block to crack resulting in thousands of dollars in damage.
The correct screw length is on the right. You should have received replacements from Mantis already.
calimanusa is offline   Reply With Quote
