A quick update: So last time when I did my pump and coolant, I didn't get most of the coolant out. Also, I followed the bleeding procedure in the Bentley book. which was fine up until the point when I had to open the cap to relieve pressure and check coolant, but I couldn't because of excessive pressure.
I don't want to risk having air pockets and such, so I got the Uview Airlift tool, and replace the coolant again. This time I got most of the coolant out, and using the tool was so much easier than doing the procedure, plus the tool can check for leak right away. For the cost, it might not make sense to buy the tool for a one time thing, but I do work on other cars, so the tool is really worth the investment, ease of use, and good result.
