Ok, I had a thought and wanted to see if anyone else has tried this. I keep seeing it is a lot easier to put back on then remove. What if you use some creative dremeling and cut the tank out so it is a lot easier to get to the hoses. It sounds like the main hose coming from the tank is what keeps it from coming out far enough to get the remaining hoses off from inside the trunk. Any thoughts?
