SmallBlock454 - the car has no power - will fire up but if you try to drive it just powers out now - this is only since they modified the CPS to fit closer to the teeth to get it to start.
Will sit and idle nice now but wont run nice like it did before above 800 RPM.
They stated the CPS was not giving a strong reading on their scope. They tried a different one they know was good and same issue - once modified to be closer to the teeth on the flywheel they got the car to start and idle but still getting an odd signal from the CPS - Stronger but somewhat erratic - Thus their belief that the there is a problem with the flywheel I installed.
I made a mistake of not checking the flywheel over carefully - had them side by side and looked really similar - but did not do a - are the teeth the same - is the gaps in the same place - is the locking pin in the same place kind of check - kicking my butt for not doing this - Still have the old one so I will be doing a thurough inspection of the 2 tomorrow night
