Old 03-17-2015, 04:57 AM   #6
Smallblock454
Thanks for the photo.
No big deal.
Leather has to be cleaned with leather cleaner to remove dirt and old contaminations. Scratches and little gaps can be filled with a special fluidleather. When it is dried the leather has to be carefully sanded with light "sanding pad" to flatten the leather surface and make it plain and smooth (not sandpaper!). Than the leather has to be dyed with a color that matches your leather color exactly. Finally the leather will be sealed with a leather fat.
Here is a good desciption which also contains videos: Risse und Löcher in Glattleder mit Flüssigleder reparieren | Lederzentrum - Spezialist für Lederpflege, Lederreparatur, Beratung
Sorry - it's only availabe in german, but if you use google translator and watch the videos i think you'll understand how it's to be done.
Scratch and crack removing and dying:
https://youtu.be/W0-p0Mj7ps4
Fluidleather repair:
https://youtu.be/_i23e228sC8
If you have a coloured leather interior it is in general air brushed with new leather color:
https://youtu.be/rhyIhfwo8vo
Hope that helps.
Smallblock454 is online now   Reply With Quote
