Guess I should of stated that I am still hunting down the no idle issue - Took it to a most recommend shop here in Calgary and after 5 hrs of diagnosis their thought is the fly wheel either has bent teeth, improperly made or is the wrong flywheel. The came to this diagnosis after checking the output of the Crank Position Sensor - They checked to see if it was a bad sensor - it was not - they modified an old sensor to go closer to the teeth on the flywheel and the car fired up but timing is out and car is not drive-able - Loaded up the car brought it home and have just finished pulling everything out of the way to drop the trany on Wed night and take a look at the flywheel.
My question is - if they sent me the incorrect flywheel would it actually fit?
