Old 03-15-2015, 02:32 PM   #1
Smallblock454
3 quarts is 2,8390588 litre. So you should have 39 ml more than you need.
Can you measure the amount you'll get out of the container? If it is 2.8 litre it should be OK.
When the engine and transmission is warmed up and if the car is absolutely leveled the transmission oil should be on level with the upper oil (fill in) hole. At nomal room temperature the transmission oil level is below the upper hole.
