usually when filling a gearbox, it is filled until the gear oil starts spilling out from the fill hole. if the three quarts don't get you there, you probably need more, if it does start spilling out you are full. if pelican recommends 3 quarts, it should be more than enough... just my opinion. if you need a little more, read the specs on the bottles you received and get a compatible oil from your local parts store. the A.P.I. specs should get you where you need to be.
2005 Porsche Boxster S, 2000 Porsche Boxster 2.7L Base, 2000 Mazda Miata LS Supercharged, 2010 Toyota Tacoma TRD Off Road
Previous Vehicles: 2005 Ford Mustang GT, 1986 Alfa Romeo Spider, 1971 Alfa Romeo GTV, 1999 Ford Mustang
1977 Toyota Celica GT
