Thread: Coolant Flush
Old 03-12-2015, 09:14 AM   #4
Smallblock454
Did you remove the water pump and water pump valve?
Have you removed both lower hoses at the front radiators?
Have you liftet only the rear, or the whole car? You have to lift the rear only.
Did you check if the coolant fluid valve is opened? (image - 5. Prüfen ob Kühlmittelventil geöffnet ist)
Did you remove the vent line? (image - 3. Entüftungsleitung trennen)
BTW: very good that you measured the amount of fluid you've drained.
