Thread: Coolant Flush
Old 03-12-2015, 07:44 AM   #2
ppbon
ppbon's Avatar
In order to get it all ...
... you should also disconnect the hose that goes into the thermostat and then raise the front of the car a bit so that the three radiators can fully drain.
Happy Boxstering,
Pedro
Originally Posted by redeye280z View Post
I am in the process of changing my coolant expansion tank and decided I would flush the whole system while I'm at it. I followed the instruction in Pedro's Garage but I only managed to get about 12 litres out of the car. The car is a 2000 Boxster S and from what I understand there should be about 18 litres in the system. what am I missing?
P.S. I disconnected the 2 big hoses as part of the draining and the drain screw.
Racecar spelled backwards is: Racecar!
ppbon is offline   Reply With Quote
