Old 03-11-2015, 10:26 AM   #8
Smallblock454
@pharaohjb:
I think it's a kind of moisture, or fluid between the polarization foil and the display glas. That would explain the pattern.
My first attempt would be to remove the polarization foil and clean the surface between the diplay glas and the foil.
Second ttempt would be to replace the foil, because maybe the polarization layer of the foil is damaged.
The LCD display itself looks OK.
