Old 03-11-2015, 05:19 AM   #15
madmodz
madmodz's Avatar
You can bypass the oem system and use and two relays and a Porsche window switch and manually control the wing. The wing motor wiring works the same as a window regulator. It has 2 wires on the motor -up and down. Reverse polarity to move in the other direction. I have also in the past used dei window controllers to wire the wing to alarm remote controls. Your sitting having some coffee when some people come to admire your Porsche. You hit your remote switch and the wing goes up.
madmodz is offline   Reply With Quote
