Old 03-10-2015, 07:33 PM   #15
Pdwight
Pdwight's Avatar
Got the bearing out
A big thanks to Dan, I was using a plate that was too large it was bottoming out on the ridge in the back of the bearing. I found one that would work and the Harbor Freight puller pulled it like a champ. Then the longer Sir B90 came in and it did not have the correct size plate to pull the bearing, just the flange so I will tackle that another time. At least now I am making progress, If my mistakes can help any other folks I am glad to go through the misery as a learning process.
My hub this afternoon after the pull
Ps what is a good aluminum cleaner I can use on this hub to help clean it up before reassembly ?
