Old 03-10-2015, 07:15 AM   #13
dan.oneufer
dan.oneufer's Avatar
On the 2003 S, removing the ball joint was the only way I had to get the drive axle out.
You should be using an adapter SMALLER than the bearing to remove it. There is a flange on the inboard side of the wheel carrier that keeps the bearing from moving. if you are using an adapter that is the same size as the outer diameter of the bearing, you are up against that flange, not the bearing. Go down a few sizes and try again.
2003 Boxster S Dark Teal
dan.oneufer is offline   Reply With Quote
