Old 03-09-2015, 02:59 AM   #8
WRC323
Yesterday I cleaned the roof and applied some water repellent.
This morning I noticed the drivers side, right side for us down under, seatbelt was damp. Under and behind seats is dry. But also the remote unlock/lock using the key fob doesn't work. I replaced the key battery the other day as it wasn't working then either. The LED in the key lights up but won't unlock the car or front and rear trunks. The key unlocks via the key hole fine and starts the car fine, front and rear trunks can be opened via the inside switches. The alarm works and arms once the door is locked, goes off if the key hasn't been put in the ignition quick enough. Tried a few things suggested in the forums but nothing has worked.
Went for a drive to Hanging Rock today. So many people up there!! Stopped for a photo op on the way back...
WRC323 is offline   Reply With Quote
