Old 03-09-2015, 02:52 AM   #1
sickbananas
OEM sports exhaust
I have a OEM sports exhaust on my boxster 2000 S. The exhaust has butterfly valves that open under vacuum through two actuators. Is anyone familiar with the system? One of the vacuum lines has melted and broken off, I would like to test the system before replacing anything.
The actuators work when I put a vacuum on then opening the butterfly valves. The vacuum feeds off the cars vacuum system and goes through a solenoid valve. I think this valve from on 12v. Does anyone know when this valve is meant to kick in?
I am think of installing a switch to control the exhaust 'manually' but would still like to know how the standard system is meant to work.
Lastly having said all of that, I assume that at rest (when the engine is off) the valves are closed and that when pulling a vacuum on the actuators it opens the butterfly valves.
de-snorkeled, clear lights, sports exhaust, zeintec hard top, zein wing, B&M short shifter, DesignTek lowering springs, DesignTek carbon fibre strut brace front and rear, 18'' carerra 5 spokes, semi slick tyres, entire soft top delete, engine cover delete,red console,L&N deep sump, volo performance chip, raptor shift light, de-cat'ed, OEM GT3 bucket seats.
sickbananas is offline   Reply With Quote
