Old 03-08-2015, 11:48 PM   #8
whitecliffs
Both marks point in OR both point out, depending on whether you are at TDC or at TDC exhaust. Bentley's and 101 Projects books are not clear on this.
If you plan to pull off both sets of cams at the same time, I can recommend using the procedure outlined in Porsche 986 Boxster Workshop manuals available in electronic version.
Cheers NewArt that was the answer i was looking for "Both marks point in OR both point out"
Yes did see insites post and it's a very good write up.
And thanks lads for all the replys, can install the motor now and hopefully she'll be running by next weekend
whitecliffs is offline   Reply With Quote
