Old 03-08-2015, 08:02 AM   #18
Luv2Box
Luv2Box's Avatar
Thanks, a lot of good info there. I was just looking at used Boxster prices and they have dropped so low that, if your 2.5L does die, it would be about the same cost to buy a used low mileage 2001 S as to do a motor swap with a new motor.
Here's the engine swap Tech Article on PelicanParts:
Pelican Technical Article: Boxster Engine Conversion Project - 986 Boxster (1997-04) - 987 Boxster (2005-08)
The 2.7 will need to be adapted for the throttle cable and the car will need a DME/ECU upgrade.
Luv2Box is offline   Reply With Quote
