Old 03-06-2015, 07:15 AM   #2
The Radium King
The Radium King's Avatar
pss9 are the big name here. I have ksports and like them. kw also make a set for the 986. note that if you do any lowering you will also require adjustable rear toe control arms (from tarett, topspeed, a few others) and, potentially, some way to adjust camber at the front - adjustable camber plates (tarett) or adjustable toe control arms (oem gt3). ksports come with built-in adjustable camber plates. you may get some bump-steer if lowered; tarett and pelican sell a product for that. if you decide to go in all the way, you will need swaybars. most aftermarket swaybars require aftermarket droplinks (except h&r, but they don't come highly recommended). typical go-to is tarett for oem-style gt3 units.
