Old 03-06-2015, 05:47 AM   #2
Deserion
Multi-Boxer Driver
Deserion's Avatar
Originally Posted by Burg Boxster View Post
before pulling door panel apart, test drop with top down using the little red clip (simulates top up). This will quickly/easily eliminate any physical hang up due to top guides, etc. From there, see if behavior is same regardless of handle (inside or out). If same, doubtful issue is either handle. Somewhere in the DIY section is a step by step diagnostic guide... do multi-word search and you should be able to find.
Good luck
I found it's not consistently hanging up on the roof. This morning I tested it a few times when I got to the office and the hang is intermittent. Wonder if it's in the replacement motor... hmm. I need to remove the door panel regardless, since the lack of a few clips is causing it to rattle when the radio is up.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
