			I would like to run led strip daylight running lights (on a 2001 Boxster S) off a "key on" wire(less than .1 amps). Is there a wire under the "hood"?I have tried to find a wiring diagram or a post but with no luck.
 I would also like to thank the members of this forum for help with the other problems. A starter key switch acting stupid, a brake switch intermittent contact, and an abs sensor just needing cleaning.
