Thread: Whining noise
Old 03-05-2015, 10:59 AM   #11
Smallblock454
If the noise goes away when you press the clutch, it's probably the gearbox input shaft that makes the noise.
If the noise goes away if you release the clutch it's probably the release bearing of the transmission.
How much miles does the car have?
When have you changed transmission oil and checked transmission oil level the last time?
And please don't use WD40 to lube pulleys.
