Old 03-05-2015, 05:21 AM   #12
KRAM36
Need For Speed
KRAM36's Avatar
Got this off a Pelican vacuum hose write up.
air intake/vacuum line routing - Pelican Parts Technical BBS
A- Fuel rail
B- Intake rubber sleeve with vacuum port (installed on the right side of throttle body)
C- Fuel pressure regulator on fuel rail
D- Air injection pump valve
E- Electronic vacuum solenoid valve for air injection pump valve
F- Vacuum reservoir
G- Four-way vacuum tee
H- Vacuum check valve (black side points toward the manifold)
I- Three-way vacuum tee (one side is plugged)
J- Electronic vacuum solenoid valve for resonance flap valve
K- Resonance flap valve
L- Intake rubber sleeve with vacuum port (installed on left side of throttle body)
It looks like it goes to E.
So where do I buy the vacuum line from?
2003 Boxster S
