Are you certain you are using the right adapter on the back? I just did this the other day with the HF kit and it pulls out easily. When the bearing is inserted, it rests against a ridge at the inside to keep it in place. I suspect you are using an adapter that is too large and is trying to pull the wheel carrier, not the bearing itself.
2003 Boxster S Dark Teal
