Originally Posted by Bigsmoothlee
Thank you for clearing that up. In addition to the car running as intended, I also want some more power. Should I get the 996 ROW tune first and then get a 996 software upgrade?
Also, do I have to worry about which throttle setup I have? Im using E-gas.
You should notice a power difference with the factory program, all 2000 & later are E-gas so no issue there. Aftermarket programing is far less cost effective for power gains so I can't justify them. None of this will affect convertable top operation.
Reason: more info
