Old 03-04-2015, 10:45 AM   #3
Bigsmoothlee
If you have installed a different size MAF housing, you have to reprogram the DME with a program for that size MAF housing. Any Porsche factory authorized diagnostic tool can do this once you have the programming codes uniqe to your DME. The 2000 996 ROW program should work great. A aftermarket program SHOULD work better,but it WILL cost 10 times more.
Thank you for clearing that up. In addition to the car running as intended, I also want some more power. Should I get the 996 ROW tune first and then get a 996 software upgrade?
Also, do I have to worry about which throttle setup I have? Im using E-gas.
Bigsmoothlee is offline   Reply With Quote
