Old 03-04-2015, 07:26 AM   #156
BoxsterLS376
Originally Posted by martsink View Post
Excellent video as usual. Where can I access these intake requirements from GM?
Also, have you considered mounting the TB on the intake manifold and using something like this tight elbow Intake Hoses, IntakeTubing, and Intake Clamps - Intakehoses.com Cobra Head Elbow 4" ID Do you think it would clear?
Those Cobra head elbows are pretty cool and **I thought at first it would work - but it won't**.
A few problems - Fitment and how/what you are attaching - these are rubber hoses which means you are intending to just mount the throttle body in the factory position. On my current mounting setup with the Renegade kit, I have right at 7" inches from the intake manifold to the absolute back of the car. Once you add the throttle body onto the manifold you lose an additional 2" inches of clearance leaving 5" inches between the furthest point a hose will fit onto the throttle body and the rear firewall... Looking at their measurements figure "C" is the most critical and as you can see it is 6.44" inches long which just won't work.
Ok so I thought just make some flanges to attach to the intake and remote hang the throttle body like I did (although it would be hanging by rubber and not a metal pipe so you would need to make a support bracket). So you would still need to make flanges and weld them to at least a short section of pipe in order to attach it to the intake plenum and the throttle body with hose clamps. I think that may work... but again now you have a different problem - the intake to throttle body pipe is 3.5" inches and it does not look like they make a 3.5" cobra elbow Perhaps a different option?
Plus I'm not sure how much those cost, but in all reality the way I did it is fairly inexpensive... I bough extra of some things as it work out cheaper in the long run - but here is a quick breakdown of my costs off the top of my head:
$30 - Custom flanges cut by local fabricator (had 4 made for $60 - have 2 extra ;D )
$49 - 3.5" 120 degree mandrel bent stainless steel pipe
$52 - 4" silicon coupler kit with clamps (5 couplers and 10 clamps, should only need 3)
$22 - 1 foot of 4" straight stainless steel pipe
$44 - 4" Aluminum 90 degree mandrel bent pipe
So I've got about $197 plus time, cutting and welding materials/tools~
Hope this info helps and good luck with your project!!!!
J
BoxsterLS376 is offline   Reply With Quote
