Old 03-03-2015, 12:51 PM   #35
JFP in PA
Tappet crown- thank you for sharing the observations.
What significance does this have for the jammed-up-in-the-bucket tappet problem?
Does the crown(offset slightly?) cause the tappet to rotate rotate ? And does a little rotation prevent jamming?
Or does jamming occur if there is almost total leak-down of oil from the tappet when the car sits for a long time ? Then when you eventually restart ,the tappet has no hydraulic 'cushion' ,so it gets hammered up into the bucket ?
All WAG but it would be good to understand this issue.
Go back and reread Jake's comments about the crown finish and hardness. If the face against the cam is not hardened, and with a crown to promote rotation, the crown will wear into a mushroom shape, making it impossible to remove, while also tearing up the cams.
Anyone that has ever wiped out a flat tappet cam will know exactly what he is referring to.
