Old 02-27-2015, 08:19 AM   #2
JFP in PA
Originally Posted by Dlirium View Post
I'm on the ECS tuning email distribution for my 986. I love and hate it. I spend more money there that I didn't know I needed to spend than I should. They are always pushing some cool thing...i really should un-subscribe :-)
Anyhow, this came today - Engine Mount Inserts. Was wondering if anyone has experience with something like this?
I know on my Z4 M Coupe, changing the motor mounts made a WORLD of difference. The cars were tuned a bit for the "masses", if you wanted a more performance oriented feel to the clutch, you definitely needed to change the motor mounts. Stock are WAY too soft.
But I hadn't considered it until ECS told me I needed it.
Details on the ECS site say:
The OEM engine mount was designed for ride comfort and is prone to sagging and tearing – above all, it is a detriment to performance. Its empty voids allow for too much engine movement, resulting in sloppy handling, numbed responsiveness, and imprecise shifting. Racecars utilize a solid metal mount to mediate this, which is impractical for street use as it transfers extreme noise and vibration into the cabin.
Any thoughts?
Unfortunately, they do not prevent the factory mounts from deteriorating, so they will not improve worn mounts to any great degree. If your mounts already have a lot of miles on them, you would be better off buying the 987 mounts which are improved over the original units.
