Old 02-25-2015, 09:50 PM   #16
com3dorm3
com3dorm3's Avatar
You LWFW guys - did you get some trick balancing of the whole c/s,bearing carrier,rods & pistons ?
I do not understand why this works well without at least a harmonic balancer on the c/s pulley. Unless you reason that the M96 is really a heavily counter-weighted 3 cylinder engine and does not need much harmonic balancing?? Because it sure isn't getting any dynamic balancing with a LWFW.
Work was done by PO and no extra/trick balancing was done.
This LWFW topic is not fully understood by many of us.
... and somewhere between the careless/uninformed and the world-is-going-to-end-fearmonger lies a balanced and harmonic explanation.
2000 Boxster S
com3dorm3 is offline   Reply With Quote
