Old 02-25-2015, 05:35 PM   #5
roma7845
have you already checked the fuse? you have to use a voltmeter or test light to check the horn relay on relay support.
Remove relay. Make sure you have voltage on pins 7 and 3. Then make sure you have ground on pin 2 when you press the horn.. sometimes the resistances of these horns are the usual culprits.
roma7845 is offline   Reply With Quote
