Old 02-25-2015, 07:22 AM   #17
Bigsmoothlee
Im pretty happy with my Ksports. No blown shocks so far... and I autoX every weekend possible. If I did have a complaint, it would be the spring rates, which I feel are astronomically high in the rear. I ended up disconnecting the rear sway bar to dial out some oversteer. But again, that could be because im running a square setup.
I wouldnt mind going down 50lbs per inch front and rear.
Some of you guys are crazy, expecting performance you can only get from a $5000 system with remote resevoirs out of a $1400 set of coilovers.
And as The Radium King already mentioned, it comes with camber plates for that price... what a great deal.
Bigsmoothlee is offline   Reply With Quote
