Old 02-24-2015, 07:59 PM   #19
KRAM36
Need For Speed
KRAM36's Avatar
Originally Posted by Ben006 View Post
I won't beat the 54$ price you show :/
I didn't know that the 997 T worked for the 986 !
But I can improve even more the design, I will work on a more "Y-ed" design, to see what I can do
I didn't figure you could. What I would focus on is getting the Y shape better then the 997 piece, if possible shorten the distance from the TB connection to the Distribution T. On the 997 part it puts the TB very far out. I would probably forget about the wedge too.
This is what I would want for a Distribution T that accepts a 76mm TB and has the same diameter tube as the plenums.
One of the problems with the 997 piece is the larger diameter tube, which also pushes the TB further out.
2003 Boxster S
