Old 02-23-2015, 04:59 AM   #1
Graniticus
Because of the MOST bus you can only use Porsche parts. In this case you can exchange the stock CDR23 with a PCM 2.1, or you can add a Dension 500 to the Most bus to add Bluetooth and AUX-In / iPod In.
Else you have to completely exchange the HU and AMP with no MOST BUS after market components. Because the stock BOSE system is a full active system, you'll have to make shure that the new components are also have a crossover and if possible time alignement etc.
thanks smallblock, the pcm is a double din, it wouldnt fit as a swap, do you have any experience with this yourself? id be more than happy to loose the boring ac unit for it which is partyl; why i wanted a flip up screen, to hide it! obvs cant take it out though...
Graniticus is offline   Reply With Quote
