Old 02-22-2015, 10:57 AM   #9
papasmurf
I would at least verify the leaf/tension springs are correctly oriented
before I spent a lot of cash having the top troubleshooted and/or repaired. Mine did the same thing when I had the parts on backwards...it's common issue if the top has been replaced or worked on at one time...5 min repair and all was well. I am assuming this is a 986 and that is an 03/04 factory top so maybe it is different. I am not saying the cables are not stretched but it might be something simpler and cheaper and is worth looking at.
papasmurf is offline   Reply With Quote
