Old 02-21-2015, 05:17 PM   #11
BruceH
BruceH's Avatar
[QUOTE=eicheldp;437258]
Originally Posted by KRAM36 View Post
4 Stalk is in and functioning perfectly. Thanks for the killer wire harness Pdwight!
Hi Kram,
I'm in the process of doing the same on mine using Pdwight's harness. My question, where did you find the shroud where the stalks protrude?
Or did you dremel the lower hole?
The rubber shroud has pre marked indentations on the back side. All you need is a utility or exacto knife to cut it out.
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
